Win Big with Expert Tips for Betting on the Level Ball Handicap (2.0 Handicap Bet)
: 2025-04-18, 04:45
In Asian Handicap betting, the 2.0 handicap bet is one of the most popular bet types, attracting millions of football betting enthusiasts every day. This bet is not only straightforward to understand but also offers very attractive payouts. So, what exactly is a 2.0 handicap bet, and how do you bet on it effectively? Let’s dive into this detailed guide from win tips bet.
What is a 2.0 Handicap Bet?
The 2.0 handicap bet is a common Asian handicap offered by many top-tier bookmakers. It means that the stronger team (the favorite) gives a 2-goal handicap to the weaker team (the underdog) at the start of the match.
You’ll find this handicap clearly listed on the odds boards of top best bookmaker in Vietnam and worldwide. It’s frequently used in matches of varying scales, especially when there’s a noticeable strength gap between the teams.
For example, Team A is the favorite, and Team B is the underdog. The outcomes are calculated as follows:
If Team A wins by a margin of 3 goals or more, bets on Team A win; bets on Team B lose.
If Team A wins by exactly 2 goals, the result is a push, and all bets are refunded.
If Team A wins by only 1 goal, bets on Team A lose; bets on Team B win.
If the match ends in a draw or Team B wins, bets on Team A lose completely; bets on Team B win outright.
While the 2.0 handicap offers high payout potential, it requires solid analysis and strategy. Let’s explore the best tips to master this deep handicap bet.
Expert Tips to Win the 2.0 Handicap Bet
1. Research Both Teams Thoroughly
The 2.0 handicap is considered a high-risk bet. That’s why thorough research on both teams is essential. This type of handicap usually applies to matches where the favorite team is significantly stronger and has high attacking power.
Before placing your bet, examine:
Head-to-head history
Recent form
Goal-scoring stats
Expected lineups
Key player performances
All this information will help you make a more accurate decision when choosing to bet on a 2.0 handicap.
for you: top 10 most aggressive football players
2. Select the Right Match
This handicap should only be used in matches where there is a large skill gap between the two teams. For example, if the top-ranked team is facing the bottom-ranked team, the 2.0 handicap might be worth betting on for a potential big win.
However, if both teams are evenly matched, avoid this handicap—it’s too risky and unlikely to result in a favorable outcome.
3. Don’t Bet Right at Kickoff
Avoid placing a 2.0 handicap bet before the match begins. Instead, wait for the first 15 minutes of gameplay. This gives you time to observe how each team is playing and make a better-informed decision.
Some bookmakers may also change the odds mid-match or shift the handicap unexpectedly—leaving bettors unprepared. Since the 2.0 handicap is deep and demanding, accurate real-time judgment is crucial.
4. Keep a Cool Head
Out of all handicap types, the 2.0 handicap is one of the hardest and demands solid experience. That’s why it’s essential to stay calm and logical before placing your bet.
Don’t follow the crowd; popular opinion isn’t always right.
Understand the odds and gather data before committing.
Never bet out of frustration or in an attempt to chase losses. This only leads to more losses, especially with high-risk bets like this one.
Many players fall into traps set by the bookmaker and end up losing everything. Staying calm and objective is the key to winning deep handicap bets.
5. Choose a Trusted Bookmaker
Finally, always choose a reputable bookmaker when betting on the 2.0 handicap. Many players suffer losing streaks without knowing why—often because they bet on shady platforms.
A trustworthy bookmaker not only provides fair odds but also ensures your winnings are paid out fully and securely. This gives you peace of mind when betting on high-stakes options like the 2.0 handicap.
Now you have a clear understanding of what a 2.0 handicap bet is and how to approach it with solid strategies. We hope these tips help you earn attractive profits from your next betting session!
Recent form
Goal-scoring stats
Expected lineups
4. Keep a Cool Head
