Everything You Need to Know About the ¼ Handicap Bet in Sports Betting
wintips12
Post autor: wintips12 »
Nowadays, there are countless types of sports bets and betting formats. You may have heard about the ¼ handicap bet, but aren’t quite sure what it actually means. Why is the ¼ handicap so popular and frequently seen in betting markets? Let Wintips help you clear up all your questions in the detailed explanation below.
What Is a ¼ Handicap Bet?
The ¼ handicap bet, also known as the 0.25 handicap, is one of the most commonly searched betting types. It’s part of the Asian Handicap system, also referred to as Handicap betting. This type of bet was created to balance the playing field between two teams in a match. Not every sports match features teams of equal strength—there are often disparities in skill or performance level.
Asian Handicap is one of the most basic and widely-used bet types. It’s especially popular among seasoned bettors. In this format, the stronger team is the “favorite” (or “top team”), while the weaker one is the “underdog” (or “bottom team”). The goal of the Asian Handicap, including the ¼ handicap, is to even out the competition and create fairer betting opportunities.
In a ¼ handicap, the favorite gives the underdog a 0.25-goal advantage. Bettors win if the team they bet on wins by a sufficient margin. If the result is a draw, bettors may lose or win part of their stake depending on which team they supported.
Breakdown of ¼ Handicap Outcomes
This 0.25 handicap, or “quarter-goal” handicap, is used when both teams are fairly even in ability. There is no possibility of a draw—only win or lose in terms of betting results.
Let’s break it down:
If you bet on the favorite and they win the match, you win the bet and receive the full payout.
If you bet on the underdog and they win the match, you also receive the full payout.
If the match ends in a draw:
A bet on the favorite loses 0.25 of the stake.
A bet on the underdog wins 0.25 of the stake.
See more: top 5 hottest female soccer players
Example:
In the Premier League match on October 23, 2021, between Wolves and Leeds United, the handicap was 0.25 in favor of Wolves (the favorite, ranked 11th, while Leeds was ranked 17th). The match ended 1–1.
If you bet 1,000,000 VND on Wolves (the favorite), you would lose 250,000 VND (¼ of your stake) and receive back 750,000 VND.
If you bet the same amount on Leeds (the underdog), you would win 250,000 VND.
Related Handicap Types: 1.25 and 2.25
1.25 Handicap (1¼)
In this bet, the favorite gives a 1.25 goal handicap to the underdog.
If the favorite wins by 2 or more goals, you win the full bet.
If they win by exactly 1 goal, you lose 0.25 of your stake.
If the match is a draw or the underdog wins, you lose the full bet.
Example:
In the Premier League match on October 17, 2021, between Everton and West Ham, West Ham was the favorite with a 1.25 goal handicap. The match ended 1–0. Because West Ham only won by one goal:
A bet on West Ham loses.
A bet on Everton (the underdog) wins fully.
2.25 Handicap (2¼)
Here, the favorite gives the underdog a 2.25 goal advantage.
If the favorite wins by 3 or more goals, the bet wins fully.
If they win by 2 goals, you lose 0.25 of your stake.
If the favorite wins by 1, draws, or loses, you lose the full bet.
How to Bet on ¼ Handicap for Beginners
If you're new to this type of betting, it's essential to understand the rules and choose a trustworthy bookmaker legit. You should also research both teams before placing your bets. Here are a few tips:
Key Tips for New Bettors
If the favorite team has a strong attacking lineup and is playing at home, while the underdog has a weak defense, the ¼ handicap may be a great opportunity to bet on the home team.
If you're unsure about the match, consider browsing betting forums, head-to-head statistics, or even watch the first half before betting in the second half.
When the ¼ handicap is offered, it's usually safer to bet on the home team, since they are more comfortable with the conditions (climate, pitch, fans).
Avoid betting on the away team if they are the underdog, unless you have strong confidence in their ability to win or draw.
The information above has been provided by the reputable bookmaker w88. We hope this article has helped clear up any confusion about the ¼ handicap and increases your chances of winning big with this popular betting type.
