How to Play the 3-Goal Handicap Bet – 6 Expert Tips for Winning
wintips12
Post autor: wintips12 »
Have you ever heard of the term “3-goal handicap” in the world of football betting? This is an exciting but rarely seen type of bet due to its high handicap margin. To understand how this bet works and to learn strategies that can boost your chances of winning, let’s explore the details with bet win tips in the article below.
What Is a 3-Goal Handicap Bet?
The 3-goal handicap, also known as a level 3 handicap, is a rare type of Asian handicap bet. This betting option typically appears when there’s a significant mismatch in strength between two teams. In this scenario, the stronger team is assigned as the favorite and must give the weaker team a 3-goal advantage.
This type of bet becomes appealing because of the overwhelming disparity in skill between the two teams. The stronger side is usually far superior in performance, preparation, and form. To balance out this advantage, best bookmaker sites apply a 3-goal handicap.
Just like with the 2-goal handicap, the 3-goal handicap can also result in a draw bet.
How to Read the 3-Goal Handicap Bet – A Simple Breakdown for Beginners
Let’s go over how to interpret this bet through a few scenarios:
Scenario 1: You Bet on the Favorite (Team Giving the Handicap)
If the favorite wins by exactly 3 goals: The result is a draw, and your original stake is refunded.
If the favorite wins by 4 goals or more: You win the bet and receive the payout based on the odds.
If the favorite draws, loses, or wins by less than 3 goals: You lose the bet and forfeit your stake.
Scenario 2: You Bet on the Underdog (Team Receiving the Handicap)
If the underdog wins, draws, or loses by less than 3 goals: You win the bet and get the corresponding payout.
If the underdog loses by exactly 3 goals: The result is a draw, and your stake is refunded.
If the underdog loses by 4 goals or more: You lose the bet.
Simple Example of a 3-Goal Handicap Bet
Let’s take a real-life example from the Chinese Super League: Guangzhou City vs Beijing Guoan.
In this match, Beijing Guoan is the stronger team and thus is listed as the favorite, giving a 3-goal handicap with odds of -0.93. Guangzhou City is the underdog with odds of 0.81. Suppose you place a $100 bet — here’s how it could play out:
Scenario 1: Beijing Guoan loses, draws, or wins by less than 3 goals
Guangzhou City wins the bet.
Winnings: $100 x 0.81 = $81
Those who bet on Beijing Guoan lose their $100.
Scenario 2: Beijing Guoan wins by exactly 3 goals
Push (draw), and both bettors get their original $100 back.
Scenario 3: Beijing Guoan wins by 4 goals or more
Beijing Guoan wins the bet.
Winnings: $100 x 0.93 = $93
Guangzhou City backers lose their $100.
Expert Tips to Improve Your Winning Odds with 3-Goal Handicap Bets
If you're betting on a 3-goal handicap, here are some essential strategies to boost your success rate:
1. Study the Teams Thoroughly
Research both teams’ history, form, lineups, injuries, and play style. These factors significantly influence the match result.
2. Track Odds Movements
Monitor sudden changes in odds. Sharp movements can reflect important news or market sentiment you may not be aware of.
3. Compare Odds Across Bookmakers
Significant differences in odds between bookmakers could signal traps or market manipulation. Don’t rely on just one betting site.
4. Manage Your Bankroll Wisely
Set a fixed budget for betting and stick to limits per match. This prevents emotional betting and helps preserve your capital.
5. Stay Patient and Emotionally Balanced
Even if you lose a bet, don’t let emotions cloud your judgment. Avoid chasing losses or overbetting out of frustration.
6. Learn from Experience
Review your past bets to understand what worked and what didn’t. Each game provides valuable insights for future betting decisions.
Conclusion
We hope this article has helped you better understand the concept of the 3-goal handicap and given you valuable strategies to play it effectively. By following these expert tips, you’ll improve your chances of success in online football nba predictions forum.
Good luck and bet smart!
