The 2-goal handicap bet is well known in football betting and often draws attention from players who want to understand it more clearly. So, what exactly is the 2-goal handicap, and how is it played? Let’s win tips bet to explore this bet and how to play it at M88.
Definition of the 2-Goal Handicap
The 2-goal handicap, also called the “level 2” handicap, is a common market in football betting. trader bookmaker usually offer this line in matches with a significant gap in team strength to ensure fairness. In this case, the stronger team (the favorite) must give the weaker team (the underdog) a 2-goal advantage before the match starts.
When you bet on the 2-goal handicap, the final score difference is what matters. No matter how many goals are scored, if the favorite does not win by at least 3 goals, your bet on them will not win.
At M88, the 2-goal handicap is usually offered only for full matches because of the large disparity it represents. It rarely appears for just the first half or second half. To play this bet well, you need solid hottest soccer players of all time knowledge and careful calculation.
Rules for Winning and Losing with the 2-Goal Handicap
If you bet on the favorite (the stronger team):
If the favorite wins by exactly 2 goals (e.g., 2–0, 3–1, 4–2), the result is a push, and your stake is refunded.
If the favorite wins by 3 goals or more (e.g., 3–0, 4–0, 4–1), you win the bet. Your payout depends on the odds set by M88.
If the favorite wins by only 1 goal or the match ends in a draw (e.g., 1–0, 2–1, 1–1), you lose the bet.
If you bet on the underdog (the weaker team):
If the underdog loses by exactly 2 goals (e.g., 0–2, 1–3, 3–5), the result is a push, and your stake is refunded.
If the underdog loses by only 1 goal or manages a draw (e.g., 0–1, 1–2, 2–2), you win the bet.
If the underdog wins outright by any scoreline, you also win the bet.
If the underdog loses by 3 or more goals (e.g., 0–3, 0–4, 1–4), you lose the bet.
How to Play the 2-Goal Handicap at M88
Playing the 2-goal handicap at M88 is simple:
Visit the official M88 homepage to access sports betting.
Register for an M88 account and complete the verification process.
Deposit funds, select a match with a 2-goal handicap, place your bet, and wait for the result. If you win, you can withdraw your winnings quickly and securely.
Tips for Winning with the 2-Goal Handicap
Analyze head-to-head history:
If the favorite has consistently dominated past encounters and often won by large margins, combined with strong current form, you can confidently back the favorite. Otherwise, if their form is inconsistent and they rarely win big, betting on the underdog may be safer.
Assess scoring ability:
If the favorite has a powerful attack and often wins by 2 or more goals, betting on them is reasonable. But if their attack is struggling, it’s wiser to back the underdog.
Check league standings:
If a top-ranked team faces a bottom-ranked team with poor form, betting on the favorite at the 2-goal handicap makes sense. However, if both teams are close in standings, the underdog is often the better choice.
By applying the knowledge above, your chances of winning 2-goal handicap bets will improve significantly. Hopefully, these tips will help you succeed when betting at M88 and maximize your winnings.
