What Is a Level Ball Handicap? Expert Tips for Newcomers to Bet on Level Ball Odds
wintips12
Post autor: wintips12 »
What is a level ball handicap, and what are the best tips for consistently winning with this type of bet? These are common questions for many beginners entering the world of football betting. The expert team at Wintips is here to share extremely useful information about level ball odds. Let’s wintips dive right in!
What Is a Level Ball Handicap in Football Betting?
Explanation of Level Ball Handicap
First, let’s answer the question: What is a level ball handicap?
According to football betting experts, the level ball handicap—also known as a draw handicap or 0-0 handicap—is one of the most popular Asian handicap odds. When a match features level ball odds, it means the bookmaker sees both teams as evenly matched, with no significant difference in skill or recent performance.
That’s why, before placing a bet on a level ball handicap, players should understand its nature and learn the right strategies to make informed betting decisions. This type of bet usually appears in matches between two evenly matched top teams, such as those in the World Cup, Euro, or Copa America.
How to Calculate Winnings or Losses with Level Ball Odds
As mentioned above, level ball is a type of Asian handicap. When betting, players choose either the favorite (upper hand) or the underdog (lower hand). Depending on the outcome and your pick, your payout will be calculated as follows:
If the match ends in a draw: You get your full stake refunded, no matter which team you picked.
If there is a winner and loser:
If you picked the winning team, you receive the payout based on the corresponding odds.
If you picked the losing team, you lose the entire amount you wagered.
Example: In a match between Brighton and Burnley, the bookmaker offers level ball odds. The payout rates are:
Brighton: 0.48
Burnley: -0.57
So:
If you bet $100 on Brighton and they win, you’ll receive $148 in total.
If you bet $100 on Burnley and they win, you’ll receive $157.
If the match ends in a draw, you get your $100 back regardless of your bet.
See detail: what does 1st half 3 way mean?
Example of Calculating Wins and Losses for Level Ball Odds
Effective Level Ball Betting Tips for Beginners
To consistently win with level ball bets, players must develop and accumulate experience. This is especially important when betting on matches where both teams have similar strengths. You’ll need to do some legwork and research to make accurate betting decisions.
Here are some tried-and-true tips from seasoned bettors for analyzing level ball odds:
Thoroughly research match details: Lineups, formations, team form, head-to-head records, player injuries, and other related stats. Having a clear and objective view of both teams will help you evaluate the odds accurately.
Monitor the bookmaker’s odds closely: From the moment the odds are released until the match starts. If the odds increase, consider betting on the favorite; if they drop, consider the underdog.
Watch for suspicious odds:
If a team has deep payout odds (from 0.6 to 0.7) but the handicap doesn’t move up to 0.25, it’s better to bet on the underdog, which offers higher payout potential.
If the match opens with a 0.25 handicap but the underdog leads 1-0 at halftime, you can consider sticking with the underdog in the second half.
Avoid betting on a draw: Level ball matches rarely end in a draw. If possible, try live betting (also called “running odds”) in the second half.
Analyze Over/Under lines alongside level ball odds: If the Over/Under line is 2.25 and one team has payout odds of 0.8, favor the team with stronger betting pressure.
Conclusion
This article from a trusted bookmaker has shared everything you need to know about the level ball handicap. Hopefully, this information helps make your betting journey smoother and more successful. Good luck out there!
