Kick-Off Bet – Strategy to Place Your Wager and Win Instantly
wintips12
Post autor: wintips12 »
Among the easiest bet types at M88, the kick-off bet is always one of the first to be mentioned. It requires no in-depth analysis or technical knowledge, making it ideal for beginners. All you have to do is predict which team will kick off first, and you have a chance to win. Let's explore this super simple yet incredibly exciting betting style with win tips bet right now!
What is a Kick-Off Bet?
The kick-off bet is a fun side bet in football betting, where the player simply predicts which team will take the first kick-off when the match begins. The kick-off is determined by a coin toss – one team chooses the side of the pitch, and the other gets the kick-off.
With a 50-50 win rate, this bet doesn't require technical knowledge, and the result is determined within seconds of the referee’s whistle. Its speed and simplicity make the kick-off bet an attractive choice for many bettors.
A-Z Guide on How to Place a Kick-Off Bet
Easy-to-understand guide to placing a kick-off bet
To place a kick-off bet, follow these steps:
Step 1: Log into your account on a reputable asian bookie handicap and ensure your balance is sufficient. If not, top up your M88 account.
Step 2: Go to the Sports section, choose Football, and look for the Kick-Off Bet.
Step 3: Based on your intuition or light analysis, choose the team you believe will kick off first.
Step 4: Enter your stake amount and confirm your bet.
Important Rules to Know When Placing a Kick-Off Bet
When participating in kick-off betting, keep these key rules in mind:
Betting time: Place your bet before the match starts. Bets placed after the match has begun will be considered invalid.
Match cancellation: If the match is canceled or does not take place as scheduled, your bet will be void and your stake refunded.
Other scenarios: Changes in venue, match time, or incorrect information will render the bet invalid.
See more: Top 5 fastest player to score 100 goals in their career
Payout Formula
Just like other side bets in football betting, the payout for a kick-off bet is calculated as follows:
Winnings=(Stake × Odds) + Original Stake
If your prediction is incorrect, you will lose your entire stake – there’s no partial refund like in some other bet types. So despite its simplicity, careful consideration is still essential!
Example:
In a match between Liverpool and Chelsea, the odds are:
Liverpool (home team): Odds 1.85
Chelsea (away team): Odds 2.00
If you bet $100 on Chelsea and they kick off first, you win $100 × 2.00 = $200.
If Liverpool kicks off instead, you lose your $100 stake.
Tips to Bet on Kick-Off Effectively
With these golden tips from Wintips experts, you'll learn how to take advantage of every opportunity in kick-off betting and turn your predictions into big wins.
1. Consider Home vs. Away Advantage
Check how often the home or away team gets the first kick-off. Usually, the home team has a slightly higher chance. If the stats show the home team frequently kicks off first, that may be your safer choice.
2. Research the Match Referee
The referee can influence the kick-off. Check which team tends to win the coin toss in matches officiated by this referee. Data from the last 5–7 games can provide valuable insights.
3. Apply the Martingale Strategy
You can try the Martingale strategy with this bet type. Start by betting on either the home or away team. If you win, continue with the same stake. If you lose, double the stake in the next round. Only use this strategy if you have the bankroll and confidence to handle it.
4. Know When to Stop
If you're on a losing streak, take a break and avoid adding the kick-off bet to accumulators. Also, don’t risk your entire bankroll on a single bet – the risk is quite high with this type.
