What Is Goal Scorer Betting? The Smartest Way to Bet on Goal Scorers
wintips12
Post autor: wintips12 »
What Is Goal Scorer Betting? – The Smartest Way to Bet on Goal Scorers
In football betting, predicting the outcome isn't limited to just wins or losses—many bettors also enjoy wagering on who will score during a match. Goal scorer bets add an exciting layer of strategy and anticipation. In this article, win tips bet will break down what goal scorer betting is and guide you on how to place these bets accurately for the best chance of winning.
What Is Extra Time Betting?
Before diving into extra time betting, it's essential to understand what extra time is. Extra time refers to the additional 30 minutes played after the official 90 minutes of a football match—divided into two 15-minute halves.
However, not every match includes extra time. It only occurs when the match ends in a draw after 90 minutes and a winner must be decided, such as in knockout stages of tournaments.
Extra time betting is a term used in football betting and is only available when extra time is played. Bookmakers offer specific odds and markets for this period.
Much like the purpose of extra time itself, extra time betting allows bookmaker streaming to provide options for players to predict the outcomes that occur during this period only. This is often the most intense time for bettors, as anything can happen.
While it’s a golden opportunity to seize momentum, extra time betting is also riskier due to player fatigue. Despite the challenges, many bettors enjoy this type of wager for its thrilling nature.
Rules of Extra Time Betting You Need to Know
To play this bet effectively, understanding the rules is just as important as knowing what it is. Depending on the tournament or competition, the betting rules for extra time may vary. So make sure to review these details carefully.
Not all matches with a draw go into extra time—some may go directly to a penalty shootout.
You can only place extra time bets after the betting board is updated and clearly states the availability of extra time betting. Wagers are based on types like Asian handicap or Over/Under, with the score reset to 0:0 at the start of extra time.
Types of Extra Time Bets That Are Counted
Will there be extra time?
Bet on whether the match will go to extra time or end in regular time.
Extra time goal bets:
Predict how many goals will be scored during the extra time period.
Match result during extra time:
Bet on which team will score and how, determining the winner and total goals during extra time.
Betting on the home or away team during extra time.
See more: top 5 best basketball prediction site
Types of Bets That Do Not Include Extra Time
First goal scorer
Team with the most goals
1X2 bets (Win/Draw/Lose)
First player to score
Time of the first goal
Odd/Even scoreline bets
How to Bet on Extra Time Accurately
If you've understood the information above, here’s how to play extra time bets effectively:
1. European Odds (1X2) Betting
You can place bets on either the first half of extra time or for the entire 30-minute period. In the first half, you bet on whether a team will win or the match will be a draw after the first 15 minutes.
If the match is interrupted during the first half, the bet is void.
If interrupted during the second half, the first half’s bet remains valid.
2. Asian Handicap Betting
Similar to regular matches, you bet based on the handicap set by the bookmaker. Once the two extra time halves are completed, bets are settled as usual.
If the match is interrupted, the bet is void.
If betting only on the first half, and it finishes without interruption, the bet is valid—even if the second half doesn’t take place.
3. Over/Under (Total Goals) Betting
Be cautious: if extra time is interrupted during the first half, the bet is canceled.
For example: if you bet on Over/Under 2.25 and the match stops during the first extra time half, your bet is void. If the interruption occurs during the second half, the result still counts.
This type of bet must clearly state it applies to extra time to be valid.
Also, if the score resets during extra time and goals cancel each other out, those goals may not count toward your bet unless explicitly stated.
Wintips hopes this article has helped you understand what extra time betting is. Before placing any bets, make sure to deposit funds to your FB88 account so you have the proper bankroll.
With the information provided, we hope your extra time betting experience becomes more exciting and successful!
