Detailed Explanation of Over/Under Bets (Tài Xỉu) for Beginners
wintips12
Post autor: wintips12 »
When participating in football betting, understanding the types of bets is the very first thing you need to do. One of the most popular and captivating bet types among bettors is the Over/Under bet, also known as "kèo Tài Xỉu." If you’re looking for everything you need to know about this bet, don’t miss this in-depth guide from bet win tips.
Comprehensive Explanation of the Over/Under Bet
Overview of Over/Under Betting
Football betting isn’t just about luck—it requires real knowledge and experience. Those who rely on gut feeling or follow the crowd without understanding the odds are likely to lose repeatedly. The same goes for Over/Under betting. While it’s not overly complicated, grasping the concept, rules, and how to read the odds is essential. Below, top bookmakers online fb88 offers a detailed explanation.
What is the Over/Under Bet?
Over/Under (O/U) is one of the three most common football bets worldwide, including in Vietnam. In this bet type, the bookmaker sets a projected number of total goals for a match, and your task is to predict whether the actual total goals scored by both teams will be over or under that number.
Betting on Over (Tài) means you believe the total goals will be higher than the bookmaker’s line.
Betting on Under (Xỉu) means you think the total goals will be lower than the projected figure.
Example of an Over/Under Bet
Let’s look at an example to better understand how this works.
Suppose there's an Over/Under 2-goal line set for a match.
If you bet on Over and there are more than 2 goals, you win.
If you bet on Under and there are fewer than 2 goals, you win.
If exactly 2 goals are scored, your bet is refunded—this is known as a push.
See more: top 5 oldest living nfl players
Tips and Strategies for Winning Over/Under Bets
Choose a Reputable Bookmaker
The first and most crucial rule in any form of betting—especially for Over/Under—is to choose a trustworthy bookmaker. But how do you find one?
A reputable bookmaker should be licensed by international gambling authorities.
It should have long-standing operations, a large user base, high security, excellent customer service, and fast transactions.
Accurate Reading of Over/Under Odds
Another critical step is knowing how to read Over/Under odds correctly. These odds come in different formats:
0.5, 1, 1.5, 2, 2.5, 3, 3.5, etc.
Being able to interpret these odds helps you decide which side to bet on for the best potential return.
Understand How to Analyze Over/Under Odds
Even professional bettors analyze every match before placing bets. Key factors to assess include:
Team form and recent performance
Starting lineups
Head-to-head results
Tactical approach of both teams
From there, you can estimate how many goals are likely to be scored.
Avoid Betting on High Over/Under Lines
Many new bettors mistakenly think that high Over/Under lines lead to big wins. However, statistically, matches with high lines tend to have smaller goal margins. In such cases, it’s smarter to bet on Under, as it's usually the more likely outcome.
Closely Follow the Match
In online football betting, the bookmaker only stops accepting bets when the match ends. To increase your win rate and choose the best timing:
Watch the match live
Monitor real-time odds as they can change during the game
Use the insights you gather to place your bet at the right time
Other Useful Tips
Manage your bankroll wisely
Don’t blindly trust all the odds provided by the bookmaker
Stay calm and composed during betting
Learn from experienced bettors to avoid common pitfalls
Conclusion
This article from top-rated bookmaker fb88 has provided you with the most detailed and complete explanation of Over/Under betting. We hope the information shared helps you understand this popular betting option and gives you the confidence to make smarter betting decisions.
