Among the many betting options in football, Over/Under odds—also known as Total Goals bets—are one of the most straightforward and widely favored by both beginners and experienced punters. This type of bet doesn’t require you to pick a winning team but instead focuses on the total number of goals scored in a match. Despite its simplicity, many players still don’t fully understand how Over/Under betting works or how to use it effectively. That’s why WinTips is here to explain the basics and share tips to help you make smarter betting decisions with this format.
What Are European Odds?
Many beginners often wonder: what exactly are European odds? Also known as "Odds" or 1X2 odds on betting boards, this type of bet is commonly used in European countries and across many football tournaments. According to statistics, European odds are preferred more than Asian Handicap or Over/Under odds by many players.
With an attractive and straightforward betting format, European odds continue to maintain a strong appeal. They have helped many bettors earn significant profits from matches. When betting on this market, you predict which football team is stronger or weaker, and then analyze and determine whether the home team will win, the match will end in a draw, or the away team will win.
How to Read European Odds Accurately in 2023 for Newbies
As we’ve discussed, European odds are based on three betting options corresponding to the outcomes: home team win, draw, and away team win. However, to read European odds properly, you need to understand how the odds are presented on the best online bookmaker board.
Some bettors may wonder why the team names appear in red at the top in some matches and at the bottom in others. The red color indicates the stronger team in the matchup, helping players recognize the strength difference between the two sides.
Unlike Asian Handicap odds, the main difference with European odds is the number of betting choices. European odds offer 3 basic betting options:
1: You bet on the home team to win
X: You bet on the match to end in a draw
2: You bet on the away team to win
Players can choose any of these outcomes depending on the potential returns they aim for. Since there are only three possible outcomes, the chance of winning is around 33.33%, which is quite high for new bettors. However, to maximize your success, it’s important to understand how European odds apply to different matches and leagues.
See more: top 5 best volleyball player woman
Pro Tips for Beating European Odds – For Beginners
Once you understand what European odds are, the next step is to learn some strategies for analyzing odds. These tips can help boost your betting accuracy:
Avoid Falling for Trap Odds from Untrustworthy Bookmakers
In many matches, professional bettors can spot disparities in odds between a home team winning and losing. However, this might be a trap set by certain bookmakers. When the odds for a team are very high, it creates an illusion of a big payout, which often tempts inexperienced bettors into making risky bets hoping for a big win.
But in matches with such wide odds gaps, winning isn’t that easy—and a draw is also unlikely. That’s why you should carefully analyze and evaluate these matches before placing your bets.
Choose the Right Time to Place Your Bets
After understanding what European odds are and how to read them, don’t overlook the timing of your bets. Choosing the right moment to place your wager is crucial for accuracy.
Ideally, place your bets 3–5 days before the match, or around 30 minutes before kickoff. These timeframes tend to offer the most stable odds. Betting too close to matchday, especially the day before, may expose you to fluctuating odds that can confuse less experienced bettors. It’s best to avoid betting during these volatile periods.
Gather All Relevant Information About the Two Teams
To play European odds well, research is key. Understanding the current situation of both teams is crucial to making accurate predictions. This includes analyzing each team’s squad, form, coaching staff, and individual players.
The nature of the match also plays a major role. For example, knockout-stage matches are often do-or-die, with teams aiming for victory at all costs. Meanwhile, friendly matches or matches with no stakes may be less competitive. Make sure to consider these factors before placing your bets.
Conclusion
Through this article from the number one betting site, we hope that new bettors now have a clearer understanding of what European odds are. European odds aren’t difficult to play — with a bit of analysis and sharp odd-reading skills, you can make well-informed betting choices. We wish you exciting and rewarding football betting experiences ahead!
