What Is the 1 ½ Handicap? How to Read It and Tips for Winning up to 99%
wintips12
Post autor: wintips12 »
“What is the 1 ½ handicap?” is a question many bettors—especially beginners—often ask. To fully understand and master this bet type, let’s win tips explore it in detail below.
The 1 ½ handicap—also known as the 1.5 handicap—is one of the Asian handicap betting lines, and it’s extremely popular today. This type of handicap is usually applied when there is a significant gap in strength and form between the two teams.
In this case, the stronger team (the favorite) gives the weaker team (the underdog) a 1.5-goal head start. This levels the playing field and makes the match more competitive. In the final result, 1.5 goals are deducted from the favorite’s score and 1.5 goals are added to the underdog’s score.
How to Read the 1 ½ Handicap Correctly
Understanding what the 1 ½ handicap is isn’t enough—you also need to know how to read it accurately. Reading the 1.5 handicap is quite similar to other Asian handicap bets:
Favorite wins by 2 or more goals – If you bet on the favorite and they win by at least 2 goals, you win your bet. If you bet on the underdog, you lose.
Favorite wins by exactly 1 goal – A bet on the favorite loses; a bet on the underdog wins.
Draw or underdog win – Any draw or underdog victory means a bet on the favorite loses.
Like the 0.5 handicap, the 1.5 handicap cannot result in a push—it’s either a win or a loss.
In short, you simply adjust the score by ±1.5 goals for the favorite/underdog when determining the outcome.
Tips for Winning with the 1 ½ Handicap
1. Bet on the Favorite in Most Cases
This handicap is often used in matches with a large skill gap, so the favorite usually has a high chance of winning. However, they must win by at least 2 goals for your bet to be successful.
2. Monitor Odds Movements Before Kickoff
Like other markets, the bookmaker online casino may adjust the odds before the match starts.
If the handicap drops from 1.5 to 1, consider betting on the underdog.
If it increases to 1.75 or 2, betting on the favorite may be the better choice.
If the underdog is playing at home and the teams’ head-to-head results are usually close, betting on the underdog can be safer.
3. Check the Starting Lineups
If the underdog opts for a defensive strategy to secure a point, it will be harder for the favorite to score multiple goals—making an underdog bet more appealing.
If both teams have strong attacking lines, you could also consider betting on the Over, especially if the favorite is playing at home and has a significant ranking advantage.
How to Place a 1 ½ Handicap Bet
Once you know how it works and have some winning strategies, you’ll probably want to try it out. First, choose a single football players 2025—this ensures your information is secure, transactions are fast, payout rates are high, and commission fees are low.
At a trusted bookmaker like fb88, you can place a 1.5 handicap bet by:
Visiting the No. 1 Bookmaker site fb88.
Registering an account or logging in.
Depositing funds.
Selecting your match.
Choosing the 1 ½ handicap.
Placing your bet.
Following the match.
Collecting your winnings if your bet is correct.
Important Notes When Betting the 1 ½ Handicap at fb88
Use accurate, real personal information when registering.
One phone number=one account.
Don’t share your account with others.
If you forget your password, use the recovery process or contact customer support.
Withdrawals must go to the bank account registered with your profile.
fb88 offers many attractive promotions—check them regularly so you don’t miss out.
With this guide, you now understand exactly what the 1 ½ handicap is, how to read it, how to increase your winning chances, and how to join a reputable bookmaker. So why wait? Sign up at fb88 today and start winning big.
